TrevorL
Jun 30, 2014Explorer
i tow with my 2011 F150 SuperCab with the 3.7 V6, 3.73 gears, and tow package.. my KZ frontier 2505 is around 4900lbs empty and i tow it no problem. max recomended towing weight is 6400lbs according to the manufactures guide. load leveling hitch and sway control is a must in my opinion. i will say that my Camper is 25 feet long and thats probably the biggest i would go with my truck. also if you can get a light weight TT in the same same size, it would be a benefit.. but from experience, i can tell you that the 3.7 V6 F150 can tow my 4900lb 25 fott TT just fine.
http://www.ford.com/resources/ford/general/pdf/towingguides/13flrv&tt_f150.pdf
