taken
Jul 28, 2015Explorer II
DavinD wrote:taken wrote:
Davin, you're truck likely weighs about 85-8700# loaded with a full tank and hitch in. My truck is an extended cab and was right at 8500 with family in, hitch in, and tank full. Your crew will weigh a touch more. So, with your 11.5k GVWR you have 2800-3000 of pin weight capacity. You really can't go by the old 20% ratio as you will likely not be towing at the trailer's GVWR and loading as well as axle placement changes things a lot from RV to RV. If you look at mine, you'd never think it could be so light on the pin but I have the CAT scale tag to prove it. So, you are on the right page with weighing a potential rig. If there is no CAT scale nearby, you could always buy a Sherline scale and check right on the dealer's lot...
I also have a pretty "full" family. Probably 550+ pounds of people.
So, another 150# off the top.
44,056 PostsLatest Activity: May 04, 2014
