- LynnmorExplorer IIDEF usage and regens are two different subjects. Def is consumed as needed at any time.
- tlerchbaExplorerUpdate. I took it to a local Ford dealer who replaced the #3 EGT sensor. O'Riley auto parts said it was the #4 sensor, but . . . They also said it didn't need a Manual Regen which I find hard to believe because I don't believe it's done one for some time given I haven't had to add and blue-def for 3 or 4 months. They also did a chip software update which is supposed to help with the mileage. However, I drove it home, about 6 miles, didn't drive it for 3 days, and when I got in it this morning the engine light was back on. So, back to Ford I'll be going. I will ask them about MAF Sensor, thanks for the suggestion. The saga continues. Again I very much appreciate all the great feedback!!!
Tim - alexleblancExploreryou've certainly got an issue, i'm getting 10-12mpg towing and in the mid-high teens mixed unloaded driving. This has been the case since I got the truck two years ago this week. (60000 km's now)
- Bamaman11ExplorerYou might want to sign into TheDieselStop.com and see what is being reported on the 6.7 engine. You may have a problem.
It seems like 18 mpg would be normal with 3/4 tons sometimes reporting 20 mpg.
I have the last of the 7.3's with a 80 hp econo tune, and I see about 20 mpg on the open road. I'm getting 11.5 mpg towing a 11K lb. fifth wheel. - MtwoodsonExplorerI have to go along with the crowd. You have something out of whack. My 2013 F350 6.7 gets 17 around town, a little more on the road and 11 with a 16K trailer behind it. Good luck.
- N-TroubleExplorer
GoPackGo wrote:
One last thought - check your air cleaner. Is it the original ? A badly clogged air cleaner can cause really bad mpg.
To go one step further pull the MAF sensor on the intake while you are at it. At dirty MAF sensor can cause all kinds of issues including horrible mileage. Don't touch the sensor (wires) though. Use an aerosol MAF spray cleaner from an auto parts store. - GoPackGoExplorerOne last thought - check your air cleaner. Is it the original ? A badly clogged air cleaner can cause really bad mpg.
- rhagfoExplorer III
TXiceman wrote:
2012 F350 CC DRW 6.7L, 3.73 axle, towing 18,000# and we get 9 to 10 mpg at 63 mph. Unloaded on the highway at 65 mph, 15.5 to 16 MPG. mixed highway and city, we generally get 13 to 14 mpg at the lowest. Lowest fuel economy was a 20 to 25 mph head wind and we dropped to 7.6 mpg, but had no problem maintaining 63 mpg.
If the OP is getting 11.8 mpg unloaded, he either has an engine problem or a really heavy foot.
Ken
X2 - TXicemanExplorer II2012 F350 CC DRW 6.7L, 3.73 axle, towing 18,000# and we get 9 to 10 mpg at 63 mph. Unloaded on the highway at 65 mph, 15.5 to 16 MPG. mixed highway and city, we generally get 13 to 14 mpg at the lowest. Lowest fuel economy was a 20 to 25 mph head wind and we dropped to 7.6 mpg, but had no problem maintaining 63 mpg.
Ken - tlerchbaExplorerAll
Thanks much for everyone's comments. This is my second diesel, first was with a 2001 Ford Excursion which I got 17/18 in the city and 20+ on the road. I am the second owner, I get about the same mileage in the city or on the road. Best I've gotten on the road was a little over 12. The overall pickup seem fine, has what I would call the usual turbo run-up slowness, other than that no real hesitation. I think I will take it to a dealer and see if it is stuck in regen mode. Any other suggestions would also be very much appreciated.
Tim
44,068 PostsLatest Activity: Jun 21, 2026
