Keith is correct and add my comments embedded below in red
Gator11 wrote:
Hey all-
I was wondering if my 2013 Yukon that has a 8100 lb.
Wich Yukon?
The Tahoe/Yukon or the Suburban/YukonXL?
All four can be half ton SUVs, with the Sub derivative a 8,600 GVWR
The 8,100 MTWR is derived from a 'curb' TV...best to actually weigh
your SUV to find out where you are in reference to the ratings. Then
note that, that 8,600 MTWR is reduced pound for pound that your SUV
is over 'curb'
towing capacity would be able to handle a Heartland travel trailer WD3175 RE? This trailer is 6995 lbs and has a 630 lb. hitch weight. It is also almost 36 ft. long. (total length)
If the tongue weight percentage of total trailer weight...it has a big
potential of being a BAD trailer. Too low a tongue weight contributes
to sway. Factored by many, but the other biggie is tongue attitude.
Meaning it should point slight down, to level at it's highest pointing
Tongue weight should be in the 12%-15% range for better/best handling
This would make me about 1100 lbs. less than my max tow capacity. I will only be towing 2-300 miles and mainly staying in a seasonal campground. I would never be in the mountains and would not have to bring water or anything extra heavy.
Mountains would exacerbate, but even level ground...think you will
have a handful and note that all things engineered/designed is for
the worst day out there when Mr Murphy crosses your path.
Either you have the proper sized and proper setup spot on, nor not.
No time to go back to the story for bigger or to resetup
Yes, distance means more time on the road and more time exposed to
the potential of Mr Murphy work
You didn't say which engine you have and assume half ton, so might
be the smaller small block...meaning I think you will be struggling
More so if you encounter head/side winds
If this would not work....what would be the max weight trailer you would suggest? Thanks for your input in advance!!
Gator
Best to go out and actually weighing your SUV fully loaded to know
Then plug that weight into the various ratings your SUV comes with
from the factory
This diagram might help you see and understand how the over all system
works (ratings)
howmuchshoulditow howmuchcanitow
