sleepy wrote:
btggraphix... good response.
I have thought about the area that I understand to be delaminated... what would cause it?
Not backing under the camper correctly? The back of the trucks bed contacting the sides of the "box" (base of truck camper between the wheel wells)
Doing it repeateably, almost every time you tried to load the TC would certainly create a need for the aluminum scruff plates.
I do hope you recieve the pictures... I wouldn't share my email address with him... the OP's posting history scares me.
Merry Xmas to you and your wife.
chet
The truck sides cannot hit the area. Delamination of anything occurs when the lamination process is flawed either by improper glue application or curing. If one part is bad very likely the entire piece is bad and just not showing yet. That is the reason we cut our losses now.
