Camper twisted so badly when level on jacks that screen door would not open and was bent prior to delivery. Twisting also caused rear compartment doors to open when latched or not be able to be opened due to tightness
I am beginning to wonder how much you know about truck campers. If they don't have some flexability built into the frame then the road vibrations and normal truck flexing as the truck goes over bumps will cause welds to break. Flex is good. What you did not do is make sure the camper is level, on level ground and that there are no stresses on the frame from poor off loading and storage. If the doors worked perfectly on the truck, they will work perfectly off the truck if correctly stored. Be glad some flex is built into the campers frame.
So where are the delam photos and why can't you share the dealers name. If the dealer is so great (even though they did not address the issues that they should have before anybody bought the camper), why not share their name?
As far as I can tell Hosts reputation is still untarnished despite your attempt to discredit and warn people to stay away from them.
