PAThwacker
May 06, 2014Explorer
ryanb-72 wrote:kvangil wrote:
FWIW, if I was towing with a 3500-lb limit, I'd go with a pop-up with a slideout. It would give you more space than a 15' hybrid, which is likely as big as you can tow with the Jeep.
X2
The wind resistance from a hybrid travel trailer would put a huge strain on the jeep.
Another alternative might be to look at a Trailmanor a hardside alternative to a pop-up but still keeps the wind resistance down. the downside is they are a bit pricey.
X3
ex 15 year jeep owner chiming in.
The jeep only has a 350lb max tonque weight. That rules out a ton of options. sends you to pups, and then run into other challenges. some pups do not allow wdh hitches,others are too large for jeeps spec.
44,066 PostsLatest Activity: Mar 14, 2015
