kelly94942 wrote:
Bumpyroad wrote:
it's a new unit? why not fuss at your dealer, et.al. what temperature is the air coming out of the vents? I assume it is ducted, you may have to adjust openings.
bumpy
Yup, it's new and we have talked about asking the dealer / manufacturer what's up. I guess I was sorta wondering if this is normal and maybe we've been spoiled in the past (our fifth wheel had two ACs).
Good idea to check the temperature coming out of the vents - any specific thermometer that gives a fast accurate reading in that sort of application?
any infrared? IIRC type, $29 at radio shack, $15 at harbor freight. shut vent in bath, be sure air is flowing out others, be sure HVAC is balanced. I added a second small AC in my 32 ft bounder. wanted one I could run when voltage was low so if I burned one up it wouldn't be the main one.
if the AC is not putting out cold air, immediately fuss at your dealer.
bumpy
