Markiemark32 wrote:
We have the small Kodiak:
First double check the vents are circulating cold air to far points (my system you have to close the vents at the unit itself which forces more cold air thru the ducts). There are instances where ducts are block off and need fixing.
Second those fancy sunlilghts we had to block off (too much of heat source during hot times), also block door window and pull shades. have to keep light out or these trailers basically become a hot-box.
Third we did get some basic fans to help circulate the air through-out the trailer.
Your Kodiak is a larger/longer one, did it have the 13.5k AC unit vs. larger 15K (might need larger unit). 13.5k is standard, 15k is an upgrade option (sometimes a dealer may have the upgraded unit).
Markiemark
Markiemark: good points, thanks. I believe we have the 13.5k, I'll have to check to make sure. I wondered if that was part of the problem... because it's such a long trailer with 3 separate rooms plus the bathroom. I'll have to check the ducts. It does seem like one of the vents in the main room isn't putting out air as well as everywhere else.
How did you block off the skylight? I can see why that would be a good idea!
