Mello_Mike
Apr 15, 2014Explorer
2013 Ram 3500 and 2011 Wolf Creek 850 Weigh-in
We had a great opportunity yesterday, while passing through Nephi, UT, to weigh our 2013 Ram 3500 and 2011 Wolf Creek 850. With a GVWR of 11,700 lbs, I was curious to see how much this combo would weigh. Compared to my recently traded-in Ford F-250, this truck's GVWR is 1,700 lbs more and has 500 lbs more payload, but part of the GVWR increase is taken up with a diesel engine and 4x4 transmission.
Well, after getting on the scales here are the results: Front Axle: 5,020 lbs; Rear Axle: 6,900 lbs; Gross Weight: 11,920 lbs. So based on these figures, I'm 220 lbs overweight with a fully loaded one-ton truck. Oh, and for the record. The diesel tank was pretty close to full, while the camper was loaded to the hilt with food, clothing, and a full tank of fresh water.
In spite of being slightly overloaded, my axles are still under weight. The Front GAWR for my truck is 6,000 lbs, but I was well under that with a weight of 5,020 lbs. The rear, on the other hand, is close to maxed out with a weight of 6,900 lbs with a Rear GAWR of 7,000 lbs.
My next task after returning home is to weigh the truck without the camper to see how much payload I truly have. The door pillar sticker says my payload is 3,809 lbs, but I want to confirm that.
