Bedlam
Apr 17, 2014Moderator
19.5" rims from Vision at rated at 4500 lbs each and Rickson's are even higher. Most G load range 225 and tires are rated around 4000 lbs and 245 G's are closer to 4500 lbs. H rated 245's can have close to 5000 lbs capacity per tire.
I vary 7000-8000 lbs on the rear axle based on loading and which trailer we take with us.
BTW: OEM rims range 3000-4000 lbs capacity for SRW trucks if you can find the specification for your particular model.
