awoodwaring's avatar
awoodwaring
2014 Chevy Silverado 1500
Looking at trying to tow a 30BHS (type) travel trailer. Most of these types of trailers are coming in with a loaded weight of 9600 lbs (give or take).
My eyes are starting to gloss over on the TV. If it lists max conventional trailering...does that mean Chevy has done the math and I can be safe with any trailer fully loaded at 9800 lbs??
Will the 3.42 axle ratio work for proposed trailer?
Specs on the 2014 Chevy 1500 5.3L EcoTec3 V8 engine 2WD (crew cab, short box)
Trailering & Payload
Curb Weight 5042 lbs
Max Payload 2007 lbs
Max GVWR 7200 lbs
Max Conventional Trailering, 3.42 Rear Axle 9800 lbs
GCWR, 3.42 Rear Axle 15000 lbs
Spring Axle Capacity 5.3L EcoTec3 V8 engine 2WD
Front Gross Axle Weight Rating 3650 lbs
Rear Gross Axle Weight Rating 3950 lbs
  • Ok...so it is this one or the 2500 (which I assume gets worse gas mileage):
    Trailering & Payload 5.3L EcoTec3 V8 engine 2WD
    Max GVWR 7200 lbs
    Max Conventional Trailering, 3.73 Rear Axle 11400 lbs
    GCWR, 3.73 Rear Axle 16700 lbs
    Rear Gross Axle Weight Rating with 3.73 Rear Axle 4100 lbs
  • GM makes a "max tow" package with a 3.73 rear end and better specs than the one you are looking at. It is called the NHT package, has upgraded rear end, brakes, cooling and built in brake controller. My '11 NHT is rated for 10.7K towing and 16.7K MCWR. Find yourself a salesman that "knows" his trucks and not the salesman who is selling the grocery getter to the soccer mommy. We routinely tow 10K with ours here in the west and are very happy with the performance and handling, but your comfort level may be different.
  • Thats 3/4 ton territory. I have the same type of trailer. I dont think you would enjoy that much weight with that truck. The specific truck you mentioned has the absolute worst rear end gear for towing too. If you dont want to go 3/4 ton maybe check the F-150 with the max payload or whatever they call it package. Tons of people on this forum can help you with the specifics on that truck
  • You are looking at upwards of 1300 lbs of tongue weight.
    Bunk house style trailer...family, kids, dogs, and lots of gear. It's going to be close.
    Think PAYLOAD...not just towing/pulling it.
