rexlion
Jul 10, 2014Explorer
Maximum payload is listed as 1420 lb, if the info I looked up is correct. I believe it's normal for a vehicle's payload to be calculated with a full tank of gas and a 150 lb driver already figured in. So that would put you closer to 600 lb. As long as you can keep your hitch weight under 750 lb, I think you'd be fine. But with a 27' TT you certainly should have a weight distribution, sway control hitch... and you have to add the weight of that unit in with the hitch weight.
I wouldn't worry about the wheelbase: 119.8" is good.
