seuadr
Sep 03, 2013Explorer
d rocs wrote:
The maximum cargo weight rating for the truck you describe is 1,826 lbs. for the ecoboost engine and 1,831 lbs. for the 5.0 engine. These weights are for a truck with minimum equipment (heavy-duty payload package option). Adding additional optional equipment will reduce the weight rating.
see, this is where things get weird.. per the document you posted - 1800 lbs payload, but per their payload website the full bed super cab 4x2 with 5.0 payload with max tow, max payload package is 2620.
http://www.ford.com/trucks/f150/specifications/payload/
so i'm not sure if the numbers you've provided are making a set of unstated assumptions or if one is overly optimistic shrugs:
