seuadr
Sep 03, 2013Explorer
wittmeba wrote:
If you provide a full description of your truck (including the wheel base as this appears to be a factor) and gearing it would help.
The only place I see 2620 is for the 157" wheel base, Super Crew, 4X2, 5.0. A Super Crew and Super Cab are NOT the same thing.
i haven't purchased it yet, so i don't have a description.. This is why i am asking this questions - beforehand.
you are correct, i mis-spoke as to the numbers.. the supercab is listed as (per http://www.ford.com/trucks/f150/specifications/payload/):
SuperCab 4x2 163" 5.0L V8 8200‡ 2710‡
the towing guide linked (http://www.ford.com/resources/ford/general/pdf/towingguides/13flrv&tt_f150.pdf):
4x2 SuperCab 163.0" 8,200 1,831
quite a disparity in numbers. now - the supercab can, in theory seat 6 - at a ford assumed 150lbs each where i am going to have 3, 200, 150 and 50. that is a 500 lb difference in passengers alone. just trying to sort out conflicting numbers.
