modexiExplorerNov 02, 20142014 F150 E-Rated Tires for TowingI have a 2014 F150 SCREW EB 2wd and a 2015 Keystone Hideout 260LHS trailer (~5100lb dry, ~640lb tongue). Usually a few hundred pounds of junk (generator, air compressor, tools) in the bed. I curren...Show More
wandering1ExplorerNov 02, 2014You need a stronger suspension than that 1/2 ton soft mushy suspension.
Related ContentE vs. D rated trailer tiresE or F rated tiresD to E rated tiresE rated tire with max psi of 65?Towing with E rated tires, that DON'T go to 80psi
