modexi's avatar
modexi
2014 F150 E-Rated Tires for Towing
I have a 2014 F150 SCREW EB 2wd and a 2015 Keystone Hideout 260LHS trailer (~5100lb dry, ~640lb tongue). Usually a few hundred pounds of junk (generator, air compressor, tools) in the bed.
I currently have 275/65r18SL General Grabber AT2 tires on my truck, and pull with a Camco Elite WDH with two friction sway bars.
I pulled it on the first long trip (300mi) a couple days ago, and noted bad sway issues in 10-15mph crosswinds, causing me to slow to 50-55mph for over a hundred miles. I adjusted the hitch once we arrived, and drove 70mi with it today in a similar crosswind, this time able to pull at the goal speed of 65mph.
I still feel a lot of squirming and the rear tires squish a lot when the trailer is loaded, even when aired to 40PSI. I know that the load ratings are safe, but everywhere I've read and everyone I've talked to seems to indicate that moving to an E rated tire would help.
I'm also interested in going with a slightly milder, while still AT tread of some kind. I prefer the more aggressive look and do take my truck on quite a few dirt/logging roads, but nothing more severe than that.
Currently I'm looking at the Firestone Destination A/T 275/65/18E tires. Does anyone have any thoughts or suggestions?
  • air to max psi cold when towing then post back... IMO no need to replace tires... just add more air
  • Also considering Air Lift Ultimate or Firestone Rite-Ride airbags.
