Rich1961
Sep 27, 2013Explorer
Keep in mind the F450 pickup is the same chassis as the 350, but with 4.30 gears and the wide trac front axle. The 450 also only comes in CrewCab/Diesel/4x4 configuration, whereas the 350 is all 3 cabs, 2 or 4 wheel drive, Gas or Diesel. The weight comparisons you have, are comparing the 450 CrewCab Diesel 4x4 (5880lbs capacity) to a 350 Gas Regular Cab 4x2(7080lbs capacity. Compare a 350 that is equipped the same as the 450, and the weights are very close.
Rich
Rich
44,066 PostsLatest Activity: Apr 10, 2026
