This might not be the right forum but.....Does the sensor that tells when to change your motor oil change when you run a different oil than what the truck came with ? I changed the oil at 5000 mil...
The OLM system is programed for spec oil. Use a better than spec oil and you will be throwing money away if you follow the OLM system. Use less than spec oil and you're putting your engine in jeopardy.
