BristolApp's avatar
BristolApp
2014 Gulf Stream
Help-on first trip with our trailer. Connected to city water. During the night water back filled thru the pump and is leaking back out of the manual fill hose. Is there a switch or valve I'm missing?
  • My model has no filter b/n the tank and the pump. After removing some plastic in the aerator on the kitchen faucet, I started to suspect junk in the lines. I took the pump apart, only to find the same small plastic strands. My guess is, when the holding tank is drilled-the plastic from inside found it's way through my plumbing. I have purchased a filter to install! Thanks!
  • There should be a check valve on the pump to prevent this, it sounds like its defective, unless you have the valve setup that you can fill the FW tank off of the city water hook up, then the valves may be in the wrong postition.
