portscanner wrote:
tad94564 wrote:
The tires and rims are not over, and neither are the axles. There is Vision 19.5 rims, with Kumho G rated tires (4500 lbs per tire/rim) on the truck. The truck came from the factory with the heavy duty suspension - the exact same suspension as the F350's of that era (look up the spring codes - they are the same)
Great! Glad to hear it! Too many people dont do their their homework and you did!
Just two questions if I may:
1. My wife is drooling over that thing and wants to know can you get in it with all the slides in?
2. What is the wet weight? I am curious!
Unfortunately, you cannot get in it when the rear slide is in, it is a total door blocker. You can some with the two sides in, but all you need is pick on, open it and you can get all the way to the front (there is a sliding door between the bathroom and shower - yes, total privacy, and a HUGE bathroom to boot!)
The weight as measured was 4200lbs; the camper does not have awning (the kitchen slide kinda blocks it), no generator (last camper had a generator, after 10years, only about 15 hours of use), no solar panels, no water, 60lbs of propane, one walmart max29 battery.
Host wants way too much for the awning, generator, solar panels.
