krazymatt
May 11, 2015Explorer
2014 Ram 2500 Coil Spring Airbag Solutions?
So I'm planning on installing some Airbags on my 2014 Ram 2500 Coil sprung pickup to help soften the ride a bit under load. I was going to go with firestone but upon research I understand their "no drill kit" does indeed require drilling due to poor fabrication. Also the instructions seem to plain old suck. Are their any other brands I can go with that might be better to install? On youtube a guy installs the firestone bags and he has to use a plasma cutter because the drilled hole location doesn't allow for a standard drill to fit. Also do these airbags replaced the springs or do you keep the springs?
