Muddydogs
Nov 05, 2014Explorer
jmtandem wrote:I'm pulling around 10,000 loaded with quads so pulling up a grade in the summer I would expect it to come on but not while running flats in below 30 degrees air temps. I have been watching my temps closely, the 2014 Ram has a nice dash display which shows trans, coolant, and oil temps on the same page.
Maybe it is not the fan. Maybe it is a temperature sensor or the ECM. Try a different dealer's service department. If the fan clutch has been replaced twice it is likely not the fan clutch.
I am beginning to think you are right. I guess They are having some problems with the clutches and I have a couple other Rams in the fleet I manage that needed to have there's replaced but these rigs run fine now.
No the fan clutch is not acting normal. Below 30 degrees air temp, coolant temp below 200 and fan clutch is on is not normal. Fan clutch shouldn't engage until coolant temp hits around 220 degrees.
44,068 PostsLatest Activity: Jun 01, 2026
