goducks10
Apr 01, 2014Explorer
I wouldn't worry about sway control with that short of a trailer, especially if your keeping the weight near 3500lbs. As long as you have the correct tongue weight it should tow fine behind the Honda. With the tandem axles and being 18' long it should be rock solid.
If you need sway control you could use this http://www.etrailer.com/Ball-Mounts/Draw-Tite/7390.html
And this http://www.etrailer.com/Weight-Distribution/Curt/17200.html
44,056 PostsLatest Activity: Jan 12, 2020
