rexlion
Apr 01, 2014Explorer
That should be a very good combo. You would have slow going up the Rocky Mtn passes, but otherwise you will probably enjoy the setup. Like the others, I doubt you need sway control but a sway bar is an option of you want it. And yes, get electric brakes instead of surge! You'll appreciate having the ability to adjust your braking force from the tow vehicle on the fly, and it's also a safety benefit that you can slide a switch over on the controller to activate trailer brakes without using the tug's brakes; if you ever did have sway, this is the way to straighten it back out. Can't do that with surge brakes.
44,056 PostsLatest Activity: Jan 12, 2020
