Capt_Eddie
Aug 30, 2014Explorer
I just watched your build. Do you plan on building a frame for the floor and putting the insulation in between? I do not understand why you laminated the two thin ply together. Treated plywood will last in these conditions. The edges of your laminated piece will be the first to fail. You did say that you were not glassing the bottom.
