davesteve
Aug 31, 2014Explorer
Capt Eddie wrote:
I just watched your build. Do you plan on building a frame for the floor and putting the insulation in between? I do not understand why you laminated the two thin ply together. Treated plywood will last in these conditions. The edges of your laminated piece will be the first to fail. You did say that you were not glassing the bottom.
I wanted a little bit more thickness than the 1/4", so I added an 1/8th. Made sure to epoxy the edges with a few coats. This piece will now be flipped over and 2x2's will make a frame and floor joists, which will be insulated with the 1 1/2" pink foam.
