davesteve
Oct 15, 2014Explorer
enine wrote:
So why did you use 2x2 instead of 1x2? Seems like it would be heavier.
My old camper which I'm pretty much rebuilding all of is 1x construction.
1x2's are awfully flimsy. That's how some of the manufacturers save weight at the expense of strength. Then they can load you up with toilets, showers, heaters, fridges, etc. So they end up with more weight and a weak structure.
I will take the extra weight of a stronger design and sacrifice on the added stuff later.
Not to say that there are not a couple of 1x2's on mine. But there are also 2x3's. Depends where you need extra support.
