davesteve
Nov 21, 2014Explorer
Capt Eddie wrote:
What is the purpose of the cut in area in the front. Where the 2 x 2 is? Is that an aluminum angle that you are using for the top frame?
The back of my truck cab window matches the size and angle of the camper side slopes, so there is no large flat part for wind to hit. So the part that supports the jack brackets is aluminum reinforced with extra bolts to the main body.
The top frame is a combination of a couple 1x2's and a pvc right angle piece, held together by screws and epoxy resin/paste. No aluminum there.
