mkirsch
Aug 25, 2015Nomad II
The last updates from last year imply that the air cylinders alone are holding up the camper. I would not trust them even if you did something like add cutoff valves at each cylinder. There are other places the cylinders can leak, and there's nothing worse than waking up in the middle of the night with your camper's roof slowly settling down on top of you!
Admittedly I haven't watched the video so I don't know if you've addressed this particular issue but I highly encourage the use of a MECHANICAL prop to back up the cylinders when the roof is raised. Again, air can, and eventually will, leak.
