jus2shy
Aug 18, 2014Explorer
Very interesting test. This is probably the closest apples to apples test I've seen in regards to the HD trucks. Usually, whenever I see a test, they pick each company's best tow configuration versus putting everyone on an even plane with the 3.73 rear end. In the end, it does show that all the trucks are really close. Also surprised at the superior braking performance of the RAM. I was under the impression that the GM would have nearly the same braking system given that they both use AAM axles and the RAM is a bit porkier than the GMC. 23' separate shortest and furthest stop. That makes a difference between hitting a vehicle or making it just in time should the trailer plug ever fall out for some reason.
