Turtle_n_Peeps
Aug 21, 2014Explorer
Why am I hung up on power?
Because you keep on saying things like:
And you said before that:
So there you flat out said gears made 35 HP. :S
This is real simple. If gears made 35 HP like you said above link me up. Show me a chassis dyno run that shows more power being generated to the ground with shorter gears just like you said above. Should be easy to show............if you are correct.
I'm done if you can't show me a dyno run or even link me up to a thread showing your point.
This is why higher gears make more power, especially on turbo motors.It's the second time you said gears make power. No they do not.
At 2500 rpms that is like an additional 35hp... So yes it does make a difference.
