GeoBoy
Jul 04, 2015Explorer
If you look at the light base AF uses butyl tape under the light base and only seal the top and sides with Geocel. If you are worried that water will enter the weep holes then pop the lens off and look to see if water can enter thru the power wires. If yes then seal the inside where the wires are.
