rklavoon's avatar
rklavoon
2015 F-250 6.2L Gas Towing 7,600 dry camper
I currently have a 2015 F-250 6.2L V8 GAS CC SB 4x4. Max Towing 12,000 pounds.
I am looking at a 2017 Jayco 32BHDS, Dry Weight 7,600 pounds. I am thinking loaded I will be closer to 9,500 pounds.
Does anyone have any experience towing this weight with an F-250/2500 Gas HD truck? I know that I will be at 75% of my tow rating, and I am not looking to win any races.... but, numbers and "feel" are 2 different things in my book. Looking for some real world feedback
I currently have a Jayco 29QBS (6,600 # dry) so I will be the same length but about 1,000 pounds heavier.
TIA!
  • I have a 34 foot gooseneck horse trailer with living quarters that weighs approx. 14,000 lbs that I pull with a 2013 F350 Dually CC with 6.2 engine and 4.30 rear end. Truck pulls this trailer with no problems - traded a 2006 6.0PSD F250 for the 6.2 gas engine with no regrets - I pulled the above trailer with both trucks and both pulled it equally well- you just have to learn to keep the gas engine in the higher rpm ranges. The 4.30 gears are awesome and only hurt the mpg about 1 mpg. I believe you will be very impressed with the 6.2 engine. Mileage towing above trailer at posted speed limits is between 8 and 9 mpg. Empty is around 14 to 15 highway at posted speed limits. Good luck
  • I have a 2016 for 6.2l and tow about 6000lbs. Tows great, won't win any races. With a weight distribution hitch easy towing. What axle do you have? Do you use a weight distribution hitch?
