Winged One wrote:
Ford Man wrote:
I have owned 2 DRW 2011 and now a 2014 and really like the looks of the rear fenders. At least they are not the entire side of the bed like GM and Dodge.
Agreed. No wide ass look. It's not ashamed to say, look, I have 4 wheels back here. LOL
No experience here, but I've read rear access to the bed is easier.
That didn't sound right! :E- Winged_OneExplorer
Agreed. No wide ass look. It's not ashamed to say, look, I have 4 wheels back here. LOL - Ford_ManExplorer
ksss wrote:
I think for 2015 Ford should put some redesign time into those dually fenders. The 08-2010 fenders look just fine. The 2011-current look like an afterthought, much like the 90's model Dodge dually's did. A new 450 pulled up next to me the other day, and it was a good looking pickup, right up until I saw those fenders, what a train wreck.
I have owned 2 DRW 2011 and now a 2014 and really like the looks of the rear fenders. At least they are not the entire side of the bed like GM and Dodge. - captainjohn2008Explorer
ksss wrote:
That's what I was thinking also.
I think for 2015 Ford should put some redesign time into those dually fenders. The 08-2010 fenders look just fine. The 2011-current look like an afterthought, much like the 90's model Dodge dually's did. A new 450 pulled up next to me the other day, and it was a good looking pickup, right up until I saw those fenders, what a train wreck. - ksssExplorerI think for 2015 Ford should put some redesign time into those dually fenders. The 08-2010 fenders look just fine. The 2011-current look like an afterthought, much like the 90's model Dodge dually's did. A new 450 pulled up next to me the other day, and it was a good looking pickup, right up until I saw those fenders, what a train wreck.
- 4x4ordExplorer III
jfritz_drfritz wrote:
4x4ord wrote:
Why??
If you are thinking of a F450 is it for towing an RV? I believe the F350 dually is much bettered suited for large RV use than a F450 is.
Buying a truck that is designed to tow much more weight than what you ever intend on hauling has one major draw back and that is it will not have the right rear axle ratio for towing your load. The transmission is most efficient in 4th gear where it is closest to putting the power straight through. A f450 running at 2800 rpm in 4th gear is capable of putting over 4000 lb ft of torque to the rear axle in 4th gear at 2800 engine rpm which equates to 53 mph. So if your hauling a very heavy load the truck is designed to put full power to the pavement at 53 mph. The f350 would put that same power to the rear axle in 4th gear at 61 mph (about 3500 lb ft of torque). When cruising the F350 would run in 6th gear at a lower rpm than the f450 and save you on fuel and running quieter. If you don't need the capability of the 450 you would be happier with the 350 dually. - Garry_GayleExplorerI have a 08 F450 6.4, thinking of going to a 15 F350 towing a 38' Mobile Suites, reasons; better fuel mileage because the 450 has 4:30 gears only, F350 has 3:55, 3:73, 4:30 depending on what you plan on towing. F350 Lower insurance cost, lower registration fees (CA) F350 better daily driver than 450 (sightseeing without trailer),tire mileage on 19.5s is not that much better than regular E rated tires in comparison to cost. Handling Comparison? use your saving to upgrade the brakes on trailer to disc. JMO as a current 450 owner.
Note in tow guide that tow rating are controlled by max hitch capacity
2015 Towing Guide - Winged_OneExplorerStole this:
Here are the highlights of changes for the 15's....
- Body/interior remain pretty much the same. Exceptions are the KR and a few new color options.
- Upgraded payload for the F450 and F350, with the F450 getting new beefier u-joints, springs, steering components, stabilizer bars, and shocks.
- Standard 19.5's for the F450
- Powertrain updates: upgraded rotating assembly, high pressure fuel pump, injectors, and completely different turbo (single). Beefed up trans internals. Overall power output 440/860 and increase in fuel economy. - NRALIFRExplorer
4x4ord wrote:
Why??
I think that was true for a few years after the '08-2010 6.4 powered models were gone. The '11 F450's maybe all the way through the '14 MY were dumbed-down abominations unworthy of the "medium duty" classification.
My understanding is that the 2015 MY will be more like the '08-'10's. Going back to 19.5 tires and beefier axles.
:):) - jfritz_drfritzExplorer
4x4ord wrote:
Why??
44,053 PostsLatest Activity: Nov 12, 2025
