rhagfo
Oct 07, 2014Explorer III
Turtle n Peeps wrote:wintersun wrote:rhagfo wrote:
good reason to carry a CO2 or Halon Fire extinguisher in the cab a couple blast in the air intake will remove the oxygen and the engine will die. I would prefer halon, as less thermal shock. Some how that engine started sucking oil from the crankcase.
What works the best is a 5 inch Crescent wrench and taking off the positive lead from the battery. I have saved one of my trucks and two other people's cars from burning up as a result of electrical shorts by doing this. With a diesel it is a good idea to know which is the primary battery.
LOL, I'm all ears. How is taking a lead off of the battery going to stop a runaway diesel? :h
It doesn't the diesel is running on uncontrolled fuel and air sources. engine electronics have NOTHING to do with it!!:E
This is why it is hard to stop, fuel (engine oil) is coming most likely from a blown seal and entering the intake system. Air is the one thing you can control, either by shutting it off, or removing the oxygen content so it wont support combustion.
44,071 PostsLatest Activity: Aug 16, 2026
