- ScottGNomadLooks like some component of the cooling system let go in the end and sprayed the hot eng with water. The head gaskets probably failed and allowed the cooling system to be pressurized with lots of boost. At least that's my SWAG.
Why do people ruin a video like that by cropping it so bad you can't see anything. Stupid! - GreentreenaExplorerWow: that is unreal! What caused that??
- 6_7_tow_rigExplorerSo what was that at the end that busted or blew up or whatever that was?
- catfishmontanaExplorer
Cummins12V98 wrote:
Could someone please post a link to this You Tube video so we can keep Fish "fair and balanced" !
The reason behind Ford's 2008 Super Duty Truck recall
That's a ford video, not near as funny as a new maxi pad biting the dust. - Cummins12V98Explorer IIICould someone please post a link to this You Tube video so we can keep Fish "fair and balanced" !
The reason behind Ford's 2008 Super Duty Truck recall - catfishmontanaExplorerLMAO, that video is hilarious at the end.
- rhagfoExplorer IIIgood reason to carry a CO2 or Halon Fire extinguisher in the cab a couple blast in the air intake will remove the oxygen and the engine will die. I would prefer halon, as less thermal shock. Some how that engine started sucking oil from the crankcase.
- Turtle_n_PeepsExplorerFrom the smoke, it's an obvious DPF failure. :B
- downtheroadExplorerMy Super Duty did that exact same thing, but it only had 700 miles on it...:)
44,056 PostsLatest Activity: Jun 25, 2013
