CoMoCo
Aug 09, 2015Explorer
2015 GMC Sierra 3500 - Check Trailer Wiring
We just purchased a 2015 GMC Sierra DRW with the Duramax and integrated brake controller. I hooked up the trailer (a 2013 Lifestyle 36FW with the standard electric brakes) for the first time and I drove around my storage yard to set the gain on the brake controller. Then I went on the street for a longer test drive. During this test drive I started getting "check trailer wiring" popping up in the info centre followed a few seconds later by "trailer connected". I pulled into a parking lot thinking the trailer plug had popped loose but it wasn't loose. So I thought there was a loose wire from the installation of the in-bed plug that was installed using the factory 5th wheel wiring provision. I was using the in-bed plug that he installed. I did not try the factory plug at the bumper.
I stopped in at the installers on my way home from work the next day and he checked the wiring he did and everything was fine. He also checked the factory plug and it was fine as well. Both had proper voltages.
I don't believe there is anything wrong with my trailer plug as I never had issues like this with the old truck - a 2009 GMC Sierra DRW with the Duramax and integrated brake controller.
Does anyone have any ideas on what else I can look for? Would putting di-electric grease on the in-bed plug and the trailer plug help?
I plan to bring the truck and trailer to the installer when I have time so he can see both together.
Thanks in advance for any help.
