Grit_dog
May 04, 2017Trailblazer
srt20 wrote:
^^^ when driving, including towing, the TC stays locks. Its only unlocked at stops. I have a durango with the v6, 8sp.
Tow package has HD cooling, HD trans cooler, bigger alternator.
Well that helps, but it still unlocks at every gear change. Makes sense though with 8 speeds it's 2x more likely to find the right gear and the tc will stay locked more often.
Still not an ideal setup by any means for towing 6000lbs.
Just an FYI though, the same basic trans ZF 8 speed whatever it's called is used all the way up to the Hellcat and possibly the Demon.
They have a few different model designations for the different power levels but realistically it is an over built unit for only 300hp and should not be the weak link in any equation with lower powered vehicles.
44,066 PostsLatest Activity: Jul 25, 2018
