AH64ID
Feb 02, 2015Explorer
We'retheRussos wrote:Home Skillet wrote:
You use premium fuel for max horsepower.
With the lower octane fuel, the power is reduced.
Incorrect. The Octane level determines the amount of pressure the fuel can withstand before it detonates. Higher performance / turbo charged engines like the EcoBoost have high compression ratios and therefore require a high octane fuel to prevent knocking. Using a low octane fuel can cause knocking and possibly damage to the engine.
On engines that require 87, they have lower compression ratios and therefore its not beneficial to put in a higher Octane. People read "Premium" and go for the marketing when it does absolutely nothing - if anything there are tests that show your MPG will go down slightly by using a higher octane fuel than recommended because your engine is not able to ignite the fuel at the opportune time.
Russia, while that information is not correct it is no neccarrially true anymore. My wife's 2003 4Runner makes more power on premium, but can run both. That is directly from Toyota. In testing it's not worth the cost of premium, unless we are towing. Since we have the truck in my sig the Runner is rarely used for towing.
Lincoln/Ford says the exact same thing about the ecoboost in the Navigator. Premium is required to make the advertised power, but the engine runs fine on regular and regular is acceptable as the main fuel.
