RCMAN46
Feb 06, 2015Explorer
AH64ID wrote:RCMAN46 wrote:AH64ID wrote:RCMAN46 wrote:
I did do the math.
The ECO makes it's max horsepower at about 5200 rpm. The 6.2 at about 5600 rpm.
The Eco near the top of the hill was in 3rd gear. With the 3.73 the ECO will turn about 4000 rpm at 65 mph.
The 6.2 with the 3.42 would be in 4th gear and will turn about 4000 rpm at 65 mph.
But the 6.2 was able to accelerate more than the ECO when both were running about 4000 rpm.
It is obvious the 6.2 was able to make more horsepower.
Not what you were talking about earlier. You made the comment that you didn't think the Eco was out of gears, I was talking about looking at what it would take to downshift, more gears, at 65 out of 3rd... It was out of gears.
I agree, the 6.2 had more power at altitude.
Here is another question, I'm not a EBologist so??, but does it have an OEM EGT sensor? Was is heat soaked and defueling? Maybe IAT was too high from the sustained near max boost?
We know that the 6.2 will lose 30% of it's power at 11K feet, and we know that the 6.2 was pulling harder at 11K feet... So that there should tell us about how much power the Eco lost at 11K feet.
You have assumed the ECO can actually make 380 hp. Ford does not have their hp numbers certified but GM does so we know the 6.2 can actually make 420 hp at sea level.
The 6.2 is in the same boat as the ECO as far as gears. If fact the ECO had an edge as it was closer to it's max hp at 4000 rpm than the 6.2 was to it's max hp at 4000 rpm.
It is interesting that both were running about 65 mph at 4000 rpm.
As for heat soaking etc are their any other excuses why the ECO does not meet expectations?
I love all the excuses made anytime a GM product performs better than the competition
I am certainly not, now nor have I ever been, in the Ford or Eco camp.. not even close.
I have been fairly neutral in this thread looking at it subjectively as I don't need/want/care for either rig. It's fun to look at the test and see how they do.
Published hp curves are not very applicable at 11K feet, the curves do change with altitude even on FI motors. Most, if not all, engines need more rpms to do the same work at elevation.
But lets get back to why I first quoted one of your posts. You made the comment that the "The Eco was not out of gears." and "I am sure the Eco had gears left." I asked you to check the math on that. How are we now talking about SAE certification and GM excuses??? It was a simple comment that the ECO didn't have the rpm band to downshift, that means out of gears. It didn't have the power to upshift and didn't have the rpms to downshift... 1 useable gear at that load and speed.
So why do you now think the GM performed better, when you said "The Eco waxed the 6.2. " 3 days ago??? FWIW I have thought the GM won the test since day 1, despite what you have said above.
If you think I am making excuses for the Eco you better think again. I am simply asking why it didn't preform to the level it should... I mean have you read about that thing on this Forum, it's an engine that walks on water, makes a 1/2 ton a 1 ton, and can do no wrong.... (heavy sarcasm).
As far as the SAE certification it's good GM does it, and Ford should follow but it's here nor there. The Lincoln won the drag race right? Base model curb weights are about the same, with the Lincoln being heavier but the GM appeared to have more options. We also know that Ford and GM both have been known to spoof curb weights.
But does the drag race prove the Eco makes more power? No, it simply means it averaged more hp over time, probably thanks to it's twin turbos. In day to day driving it's about hp over time. It's why torque numbers make a difference, more torque (with a peak hp below 5252 rpm) means more hp in the everyday rpms even if peak hp is a little lower. Does the peak hp help win a drag race? Or a towing race? Yes it does, but higher peak torque will win over time. (Prime example, my year truck the Hemi was a 345/375 and the Cummins was 325/610. The Hemi has the hp advantage yet the Cummins will walk all over it towing. HP is important, but it's a lot more than peak hp that needs to be looked at).
All we know is that a 420hp NA motor will drop to about 300hp at the wheels, and that the 300hp was enough to accelerate at approx 14K GCW but that the Eco couldn't do that. Why?
It's a simple why... a 380hp FI motor shouldn't lose more than 20% of it's power at 11K feet (but will lose some), but it appeared to. So that's the question on heat soak, EGT sensors, or is it simply Ford's lack of SAE certification?? It's an honest question that has nothing to do with brand loyalty, EcoBashing, EcoLoving, EgoGrowing, etc...
"The Eco waxed the 6.2. " 3 days ago???"
A misquote so I will not respond to anything above. It is not clear what your were driving at anyway.
