Bedlam
Sep 13, 2017Moderator
You may be over the tongue weight limit of 750 lbs on that SuperTruss without using any WDH. Extending your tongue length would lighten up that weight without causing handling issues or requiring W/D.
http://www.torklift.com/index.php/products/towing/superhitch-supertruss
Your rear axle weights are about 500 lbs heavier than what was on my short bed F250 with a 4000 lb TC and 8000 lb trailer using the same length truss with a WDH.
From what I have read, 34" tall tires will rub slightly at full turn lock and anything taller requires a front leveling kit to clear your Ram 3500. You will not be able to use chains or cables on the front axle with those 34" tires unless you do something to the suspension.
