kohldad wrote:
I really doubt it unlocked when dropping into 5th.
It definitely unlocks when it downshifts. You can vary the throttle and watch the rpms changes. After the downshift, if you ease off the throttle, you can see the rpm drop as the torque converter lock back up.
That does not sound right. i can see unlocking from 5-6 to save the trans from a harsh shift. 6-5 should go from lock to lock or at least a short flair before locking. Towing in fluid coupling instead of lockup causes a lot of heat generation.
I am for sure not a Gasser expert.
