Homeless_by_Cho
Oct 13, 2016Explorer
shellbackcva59 wrote:
Thanks for the replies, but I need to know where to look for the antenna connection under the dash. Earlier models show it behind the glove box. Doesn't seem to be the same with my truck.
The antenna is located on the back side of the radio. Just unplug the existing one and insert the new one.
Now comes the more challenging part. To get to the back of the radio, you need to pry off the front surround from the radio. Get a stiff 1 inch wide steel putty knife and insert it between the dash plastic and the radio surround plastic and PRY. Don't be bashful, those dang spring clips are really hard to pop out. A plastic putty knife will break before the clips let loose.
Once the surround is removed, then remove the metal screws and gently pull the whole radio out. Have something handy to support the radio while you remove the existing antenna and thread the new antenna thru the bottom of the dash. Several blankets, bed pillows, etc come in handy as a support. It may take you upwards of an hour to finally choose the wire path and secure it before you end up plugging into the radio.
Good luck,
LeRoy
