Grit_dog
Jul 04, 2018Trailblazer
When the truck is empty you won't know the Timbrens are there, unless you shim/space them up so tight that they don't let the suspension compress at all. Becasue remember that your 2500 rear suspension doesn't move much during normal driving, it's stiff without a load.
Your back tires being aired up to keep the idiot light off will be what beats you up. I'd lower those suckers to 40psi when not hauling and enjoy the best riding rear suspension of the big 3.
Don't get fooled into airbags on the Ram 2500 with a high CG load like a truck camper, period. You do not want to add "bounce" to the coil springs. Those reccomending bags, especially when they're not needed either, based on the picture, are not aware of the Ram coil rear and how it acts. It's not ideal for TCs, but light to moderate ones like the OPs Cirrus should fare well without rocking the boat too bad.
44,068 PostsLatest Activity: Jun 17, 2026
