memtb
Apr 26, 2019Explorer
You may also consider a Mag-Hytec differential cover. These offer more capacity ( lowers oil temps a bit), a sight glass to easily monitor your fluid level, a magnet in the drain plug to keep metal particles from traveling around in the oil, also has a threaded port where you can put in a temperature sensor/ sending unit so you can monitor your rear differential temperatures. This is a helpful addition to your tow vehicle..... especially if, you do a lot of heavy towing in mountainous regions!
44,068 PostsLatest Activity: Jun 09, 2026
