Grit_dog
Apr 26, 2019Trailblazer
SweetLou wrote:Cummins12V98 wrote:Ron3rd wrote:Cummins12V98 wrote:
Highly advise dumping the OE fluid and run AMZ/OIL SevereGear 75–90.
Good info. Do you know the capacity? I've seen conflicting info online
I just did a 3500 11.5” rear axle and it took a hair under 4 quarts.
How much goes into the front transfer case for 4x4?
Transfer case or front axle?
Front axle is about 2.5qts.
T case is about 2 qts but takes ATF not gear lube. All the capacities are in your owners manual for reference.
44,068 PostsLatest Activity: Jun 09, 2026
