2BLAZERS
May 18, 2016Explorer
Bedlam wrote:
You need the tall skinny tires - The wider ones will float more (yes, even with all that weight) and not give you as much bite.
The 34*10.5/17 BFG KOA's AT are my choice now. They will be just an inch wider than stock...so should work. Will be researching more.
These will also get wide enough to get me on the sand if I drop the pressure enough. And another inch of ground clearance would be great too.
