tama2112
Jun 15, 2017Explorer
RoyJ wrote:tama2112 wrote:
Hi all, just updated my post. Hoping to get some feedback from the experts. Thanks!
Are you willing to change out the wheel and tires to high capacity ones? 19.5s, or at say, LT295/70R18s that are rated at 4080 lbs.
Like everyone else have been saying, stock, your truck will be rear axle weight limited, especially seeing you've gone up in pin weight.
Most SRW 1 tons have plenty of axle capacity, it's the single tires that's the limiting factor. The axles are identical to DRW versions in most cases.
Thanks for your post. This brings up an interesting question. Technically, the only difference between my truck and a dually is an extra set of tires in the back, correct? So it's really not the axle or the rims that are lacking. It's the tires, right? Wouldn't it make sense that if I exchanged for some G or H rated tires that would solve the problem?
44,056 PostsLatest Activity: May 04, 2014
