crasster's avatar
crasster
Explorer II
Jan 25, 2020
2017 Chevy 6.0L 15 Passenger van
GCWR 16,000
Van weight is 6,129
I have 900 pounds of passengers.
We'd like to tow a 6,660 pound RV. I did the math and included LOTS of details on extra weight.... pretty much we'd have a spare 1,400 to 1,500 pounds (roughly depending on tank levels) amount till we hit GCWR.
With a WD hitch and sway bar, will this van handle the Trailer well? I'm curious how it will do on grades / mountains.
I've pushed it years back with a Toyota Sienna and came within 300 pounds of GCWR on a small KZ. I didn't like it. White knuckled a bunch in Colorado.
I know my Chevy Express is a different class of vehicle totally for towing. This time 1300-1400 pounds off GCWR.
Looking for tips, suggestions, comments, moral support. LOL :)
Thanks!
  • You will have no problem, but I would recommend replacing the shocks. It will not win races, but gets the job done. I appreciate the non-towing fuel economy. When you get get over 16 mpg with 10 or more people, it is efficient.
  • OP posted that his van has a 9,600 GVWR
    So already has LT tires on his 1 ton van
  • Sounds like you'll be just fine. The only thing I'd add is you might want to go to a LT tire for added stability.
  • APT wrote:
    Go for it. Flush the fluids. Let that engine spin to 5000rpm when accelerating or uphill. Use tow/haul mode for transmission. I like to use M5 and M4 to limit the top gear, but many just use drive. Enjoy.
    Thanks! :)
  • Go for it. Flush the fluids. Let that engine spin to 5000rpm when accelerating or uphill. Use tow/haul mode for transmission. I like to use M5 and M4 to limit the top gear, but many just use drive. Enjoy.
  • Probably because he wasn't sure where it went. Why do you care?
